Guide to play correct score bet in football betting
Wysłany: Pią 10 Maj, 2024   Guide to play correct score bet in football betting
Correct score betting is favored by many players due to its popularity. For those experienced in football betting, it's likely nothing new, but what about newcomers? Do you understand this type of bet? Let's find out more in the following sure football tips by Wintips!
What is correct score betting?
Correct score betting, also known as "correct score," is considered a quite common form of betting that requires players to predict the exact outcome during the official match time. The bookmakers will offer a betting ratio, and players predict if correct to receive an appropriate reward.
Currently, there are many different forms of correct score betting on the market, but the three most popular types are as follows:
Asian Handicap Correct Score
This is a type of bet chosen by many and highly rated. The stronger team will handicap the weaker team by a certain ratio based on the difference in strength between the two teams.
European Correct Score
This is a simple form of bet chosen by many punters. You just need to predict the outcome you want. No need to worry about the score or goal difference; all you need to know is which team wins and which team loses.
Total Goals Correct Score
This type of bet is based on the total number of goals both teams will score in the official 90-minute match. Typically, the bookmaker will offer odds where the over option has higher odds than the under option.
How to calculate money in correct score betting
In addition to understanding the concept of correct score betting, one thing that bettors need to pay attention to is how to calculate money in this type of bet.
The formula for calculating correct score betting is as follows:
Winnings=capital x odds.
For example: In a match between teams A and B, you place a bet of 100,000 dong, and the score is 3-1 with odds of 0.97. If you win, you will receive: 100 x 0.97=97,000 dong. Conversely, if you lose the bet, you will lose the entire amount of the bet.
You can use this formula to check the credibility of the bookmaker. At the same time, you can easily calculate the amount you will receive when you win.
Watch now: what is an asian handicap in soccer
Expert Tips for Betting on Match Scores
Although considered a simple type of bet, winning this type of bet is not easy. Besides understanding the concepts and rules, it also requires applying many experiences. Below is a compilation of match score betting experiences from top experts at Wintips.
Choose leagues that you understand well
Currently, there are thousands of matches taking place worldwide every day, but each league has its own characteristics. Therefore, it is best to choose leagues that you are familiar with. This will help you understand the tactics, betting strategies to enhance your chances of winning.
Select teams you are fond of
In a match, if you are a fan of one of the two teams, predicting the outcome becomes easier. This is also the reason why there's a saying "know yourself, know your enemy, and you shall win every battle". When you are a fan of a team, you will understand their style of play, squad dynamics, player form, attacking and defensive strategies, etc.
By regularly following, you will be able to make accurate decisions for yourself.
Hone your match prediction skills
Anything you want to excel at requires practice, including betting. Many seasoned players choose to hone their match prediction skills. If you don't understand your opponent, it will be difficult to make accurate predictions. Although betting is a game of chance, it doesn't mean you can rely solely on luck. You need to grasp skills and experience to increase your chances of winning.
Therefore, if you want to win, practice predicting scores before matches. If you often make incorrect predictions, learn to analyze the odds to make the most accurate decision. You should analyze based on factors such as playing style, physical condition, and form of the two teams.
Choose favorable betting types for yourself
Analyze the odds that bookmakers offer and choose the option that favors you. You should choose handicap or even bets if the underdog team is in good form or the top teams are evenly matched.
Avoid betting on too many matches at once
Experienced bettors advise not to bet on too many matches at once. Betting on multiple matches simultaneously means you won't be able to analyze thoroughly. You should choose to bet on one match to analyze the playing style, tactics, and team style thoroughly. This way, you can make the most accurate odds for yourself.
Refer to odds from multiple bookmakers
Each bookmaker will offer different odds, so as a smart player, you should not place bets immediately when a bookmaker offers odds. Instead, participate in multiple bookmakers to choose the most suitable match score bet for yourself.
Monitor the odds closely
Typically, bookmakers will release odds 5-7 days before the match. Besides, players can also bet even when the match is underway. However, odds may change depending on the number of players. According to the betting experience of experts, you need to update the odds regularly to make the most accurate decision for yourself.
Choose to bet on reputable bookmakers
Currently, there are many bookmakers on the market. However, when participating in betting, you should choose reputable bookmakers that offer a variety of betting options. Additionally, they must have diverse deposit and withdrawal methods. Especially, they must offer better odds than other bookmakers.
Maintain stable psychology throughout the betting process
Psychological factors play an extremely important role in sports betting. Whether you win or lose, always remember to stay calm. Do not let psychological factors affect your betting decisions.
Even when you win, do not bet based on emotions but rather conduct thorough analysis. Conversely, when losing, do not have a winning or losing mentality. Take a break to adjust your emotions and then consider the most advantageous decision.
Manage your capital well
Capital is a necessity when participating in betting. Not only for match score betting but for any type of bet. However, not everyone can control their capital well. The best players should divide their capital into several parts, absolutely not put all their money into one match. Instead, think carefully to maintain long-term play without running out of capital.
Match score betting is a fairly common type of bet in football betting. It requires players to have skills and betting tips app experience to win. Hopefully, the information we shared above will help you achieve victories for yourself.
