The Difference Between European Odds and Asian Handicap
nguyencuong0704
Wysłany: Sob 30 Gru, 2023   The Difference Between European Odds and Asian Handicap
The Difference Between European Odds and Asian Handicap in Football Betting
In football betting, there are various types of odds for enthusiasts to choose from. Each type has its own interesting points. Do you know what the difference between European odds and Asian Handicap in football betting is? Let's explore and bookmaker ratings with the assistance football betting sites.
What Are European Odds?
European odds are one of the commonly chosen types of football odds nowadays. Initially exclusive to the European football betting market, they have gained popularity in domestic and Asian competitions as well.
In essence, European odds are simply the odds for a half or full match. This type of odds involves three betting options based on the overall result of the match: home team win, away team win, or draw. Players don't need to worry about calculating scores or handicap ratios, making it simpler compared to other types of odds.
Currently, European odds include two subtypes: European odds for the first half and European odds for the full match. You can explore additional content such as tip online bookmaker australia on various platforms.
What Is Asian Handicap?
Asian Handicap is a familiar and highly favored type of odds among Vietnamese bettors. It is also known by various names such as Handicap or Handicap odds. The odds are calculated based on the match score over 90 official minutes plus injury time, excluding extra time.
Asian Handicap appears first on the bookmakers' odds board and comes with various and diverse odds ratios. These odds are specifically tailored to the Asian market.
Differences Between betting site uk Odds and Asian Handicap
While both European odds and Asian Handicap are widely used in football betting, many players wonder about the differences between the two. To place accurate bets, players need to understand the essence of each type of football odds. Some key differences highlighted by leading experts and professional bettors include:
Betting Principles and Formats
When comparing European odds and Asian Handicap, the first consideration is the betting format and the principles of analyzing odds.
In comparison to European odds, Asian Handicap has an advantage in terms of the variety of betting options. Asian Handicap allows players to place a wide range of specific handicap bets (up to nine) to increase their winning chances. European odds, on the other hand, limit the number of betting options, typically only offering three: Draw – Home Win – Away Win. This limitation can make it challenging for players to find favorable odds.
Moreover, with European odds, players only need to focus on the overall result of the match. For Asian Handicap, players must pay attention to the number of goals scored in the game.
The differences in betting formats and odds opening between the two types are evident. The degree of influence from bookmakers on the betting market also plays a role.
For seasoned bettors, European odds and Asian Handicap are familiar, making it easier for them to analyze and select suitable betting options, enhancing their chances of winning.
Odds Ratios in Each Type of Odds
Calculating odds ratios between European odds and Asian Handicap highlights one of the most significant differences.
For European odds, when you win a bet, the amount is doubled. In Asian Handicap, players only receive a profit of 0.85. In case of losing a bet, players lose the entire amount they placed, without any deduction (0.85).
For instance, with European odds at 1.9, winning a bet means receiving an amount equal to the initial wager multiplied by 1.9. If you bet 100,000 VND and win, you receive 190,000 VND. The total amount received is 290,000 VND (winnings + initial wager).
For Asian Handicap, the production figures may vary depending on the bookmaker and the country. In Asian Handicap, players can bet with handicap odds such as 1, 1.25, 1.75, etc. The odds can change based on the performance gap between the two teams, providing a relatively complex but versatile betting option compared to European odds. Although more intricate, it is easier for players who want to participate in a wide range of betting options and meticulous calculations.
Terminology Differences
Another difference between European odds and Asian Handicap is the terminology used. This helps players distinguish between the two types of bets.
European odds do not have a specific name but are expressed through the 1×2 symbol. In contrast, Asian Handicap has various names such as Handicap or Handicap odds and is symbolized by HDP.
In conclusion, understanding the differences between European odds and Asian Handicap is crucial for football betting enthusiasts. Each type has its advantages and nuances, allowing players to make informed and suitable betting decisions based on their preferences and strategies.
https://nhacai10.com/
