Guide on How to Calculate Betting Money in Soccer Betting Ac
Wysłany: Czw 26 Paź, 2023   Guide on How to Calculate Betting Money in Soccer Betting Ac
Calculating the money in soccer betting is a difficult problem that many players find quite challenging. Today, to help our fellow gamblers make more informed bets, Wintips will guide you on how to accurately and easily calculate betting money. This method is widely used throughout the country.
Win big with our expert no loss football tips
Learn how to calculate betting money in soccer betting accurately 100%.
Currently, there are various types of betting odds in soccer betting. Players only need to rely on the selected betting format to calculate their win/loss ratios and the amount gained or lost. You should refer to articles on how to read soccer odds on various bookmakers' websites to better understand how to calculate soccer betting money.
Below are the most detailed and easily understandable guidelines for novice players to reference.
How to Calculate Money in Soccer Betting When Winning
In soccer betting, a player's win can be divided into two types: full win and half win. Depending on this, the method of calculating the betting money will also differ.
Calculating Money Based on Asian Handicap Betting
Asian Handicap, also known as 1x2 betting, only offers two betting options, so players can either win or lose. In this case, you can calculate the winnings as follows:
A full win means that you have won the entire match. Players will receive the winning amount according to the following formula:
Full win amount=Betting amount x Betting odds.
For example, if a player selects the 1x2 odds for the match between Crystal Palace and Manchester, places a bet of 100,000 VND on Manchester to win, and the displayed odds for this team are 1.63, and Manchester wins, the player will receive a total amount of 100,000 x 1.63=163,000 VND.
A full loss means that you have lost the entire match. In this case, the player will lose the entire betting amount placed on that match. The formula for calculating the amount lost is as follows:
Amount lost=Betting amount.
For example, if you bet on the 1x2 odds with a stake of 200,000 VND on Real Madrid to win against Chelsea, and Chelsea wins, the player will lose the entire 200,000 VND betting amount.
Use betting tips app to win easily : soccer tips app
How to Calculate Money Based on Asian Handicap Bets
Asian Handicap or Handicap bets involve calculating the amount of money wagered based on the odds for each match. The positive and negative odds ratios in this type of bet show the actual amount of money that the bookmaker receives from the players, which is different from other types of betting. The calculation of winnings and losses also differs slightly based on this.
Note: Original amount=Amount wagered x Odds ratio.
For example, if you place a 300,000 VND bet on an Asian Handicap for the Thai team with odds of 0.99, the actual amount that the bookmaker receives from the player will be 100,000 x 0.99=99,000 VND.
How to Calculate Money for Over/Under Bets
Over/Under bets, also known as Over or Under bets, have a similar calculation method for betting on soccer matches to Asian Handicap bets. Therefore, in this type of bet, you can have scenarios where you win, lose, win half, or lose half. You should apply the same formula used for Handicap betting to Over/Under bets to calculate accurately.
Over/Under bets are a good choice for beginners in soccer betting. For more details, you can find all the information you need in the article "What is Over/Under Betting and How to Bet on Soccer Goals" on the website.
How to Calculate Money in the Case of Refunded Bets
This situation can only apply to Asian Handicap bets or Over/Under bets (Asian Handicap does not consider a draw result). If a player's prediction neither wins nor loses, they will receive a full refund of the amount they wagered. This is considered a somewhat special case when choosing certain types of bets with handicaps ranging from 1 to 3 goals.
Some Important Points to Know About Calculating Betting Money in Soccer
To calculate your betting amount accurately, you need to know the odds provided by the bookmaker precisely. Each match and each bookmaker may have different rules, so you cannot apply a single odds ratio. If you want to participate in various betting platforms, make sure to understand all the information provided by the bookmakers.
In essence, the formulas for calculating betting money at different bookmakers are quite similar. However, you must distinguish between different types of bets, such as Asian Handicap, Handicap, or Over/Under, to calculate accurately. Lastly, make sure to choose a reputable bookmaker to avoid recalculating your soccer betting money after each game.
View more articles : soccer tips telegram
Wintips has shared these formulas and methods for calculating soccer betting money in a detailed, specific, and beginner-friendly manner. Apply these formulas to predict your own wins and losses. Join and test the reliability of this bookmaker.
