AARHUS AGF VS NORDSJAELLAND MATCH ANALYSIS
phocohanoi7
Wysłany: Pon 31 Lip, 2023   AARHUS AGF VS NORDSJAELLAND MATCH ANALYSIS
Key: The last 5/6 matches of Aarhus AGF were about fainting.
Comment on match results
Aarhus AGF currently has 3 points, ranked 5th on the Danish football league table when winning 1 scoring 1 goal and conceding 0 goals. On all fronts, the Ceres Park stadium home team lost the last 2/9 matches, the last 0/10 matches at home. According to Asian rafters, Aarhus AGF did not win the last 4/5 matches, did not win the last 4/5 matches at home. With a worse performance than the away team, the excellent Ceres Park stadium home team will not be able to win against Nordsjaelland to bring joy to the home audience.
Looking for the soccer tips bet to help you win your bets? Check out our comprehensive guide to the top-rated soccer tips sites with expert analysis and high-quality picks.
Nordsjaelland is also in pretty bad form in recent matches. Nordsjaelland before this match has 3 points when winning 1 scoring 4 goals and conceding 1 goal ranked 2nd in the rankings. However, Nordsjaelland won the last 3/6 matches, won the last 5/9 matches.
Judging the number of goals
Statistics show that the last 5/6 matches of Aarhus AGF, the last 8/10 matches of Aarhus AGF at home, the last 4/5 matches of Nordsjaelland, the last 5/7 matches of Nordsjaelland away from home have been from 2 goals or less. Therefore, there is a high probability that the confrontation at Ceres Park between Aarhus AGF and Nordsjaelland will only have 2 or less goals at most.
Aarhus AGF vs Nordsjaelland Head to Head Analysis
Confrontation history shows that in the last 10 away games at Ceres Park, coach Flemming Pedersen's team won 5 draws 2 lost 3, 5/10 matches ended with at least 3 goals scored. Scored, in the last 2 visits Nordsjaelland won 1 draw 1. Counting the past 20 confrontations, Aarhus AGF won 7 drew 6 lost 7, 11/20 matches had no more than 2 goals scored, only 4 times counted. Last confrontation Aarhus AGF won 1 draw 2 lost 1.
Performance Analysis Aarhus AGF vs Nordsjaelland
Aarhus AGF did not win the last 6/10 matches, won the last 3/5 matches. At home, coach David Nielsen's army won the last 5/10 matches, not winning the last 3/5 matches.
Nordsjaelland did not win the last 6/10 matches, did not win the last 3/5 matches. Away from coach Flemming Pedersen's team did not win the last 9/10 matches, did not win the last 4/5 matches.
Find the football tips website with our expert guide, featuring in-depth reviews and analysis of the top sites for soccer betting tips and predictions.
Analysis of Asian handicap Aarhus AGF vs Nordsjaelland
Aarhus AGF did not win 6/10 recent Asian matches, of which the last 4/5 matches did not win. At home, coach David Nielsen's army won the last 5/10 matches, did not win the last 4/5 matches.
Nordsjaelland won the last 5/10 matches according to the recent Asian rafters, of which the last 3/5 matches did not win. Away from coach Flemming Pedersen's team did not win the last 6/10 matches, did not win the last 3/5 matches.
Aarhus AGF vs Nordsjaelland match performance analysis
According to the over and under, Aarhus AGF finished in the last 5/10 matches, in the last 3/5 matches. At home, coach David Nielsen's army was in the last 8/10 matches, in the last 4/5 matches.
According to Nordsjaelland over and under, about the last 5/10 matches, the last 4/5 matches. Away from home, coach Flemming Pedersen's team has fainted in the last 6/10 matches, lost in the last 3/5 matches.
Select: Nordsjaelland (+0).
Prediction of over and under: Under.
Predict the score: 0-1.
What is F1 racing betting? Information related to F1 racing betting. Retrieved from https://wintips.com/what-is-f1-racing-betting-information-related-to-f1-racing-betting/
Strona wygenerowana w 0,11 sekundy. Zapytań do SQL: 12
