Guide to Play Combo Bets in Football Betting
Wysłany: Wto 20 Cze, 2023   Guide to Play Combo Bets in Football Betting
Combo bets are always a popular choice among many bettors when it comes to multiplying their capital. However, not everyone is clear about what combo bets are and how to play them accurately. If you're facing this issue, today's article from Wintips is here for you.
Stay ahead of the game with our football tips over 1.5
Sharing what you need to know about combo bets
Combo bets, also known as accumulator bets, involve placing multiple bets on different events to create a new set of odds. When participating in combo betting, it is not necessary to win all the bets; predicting the majority of the outcomes can still be considered a victory.
The probability of winning one match is 1/3.
The probability of winning two matches is 1/9.
The probability of winning three matches is 1/27.
Usually, the winning rate will be proportional to the number of matches. Therefore, the more bets included in the combo, the higher the winning rate. For each additional match, you multiply the winning probability by 1/3. It is because of this reason that combo bets, despite being high-risk, are still favored by many players.
Under the appeal of the huge winnings when winning the bet, the number of combined bets for each combo can increase. If you combine 4 matches, it is called a 4-fold combo; 5 matches would be a 5-fold combo, and so on. The sequence continues to increase, resulting in 7-fold, 8-fold, 9-fold combos, and so forth.
Guidelines for placing simple combo bets
Understanding what combo bets are is not enough to secure a win. Therefore, the following tips on how to select combo bets will provide essential information for beginners to remember.
Guidelines for calculating combo bets when betting on Asian Handicap and Over/Under
If you frequently follow and engage in betting, you will find that this is the most popular form of combo betting today. When choosing this type of bet, you can apply the following formula to calculate the combo bet:
Combo Odds=Winning odds x [(Odds when winning ½ - 1)/2] x ½ (if losing half) x 1 (if drawing) x ... X Odds of the nth bet.
In the case where the winning odds are calculated using geometric progression, apply the formula in each specific combo bet as follows:
When betting on a combo where any match wins half, use the formula: [(Bet odds - 1) / 2] + 1.
When betting on a combo where any match loses half, divide the combo odds by 2.
These guidelines will help you better understand what combo bets are and how to calculate them accurately. Remember to apply them carefully for a successful betting experience.
Unlock your winning potential with our what's an asian handicap bet
How to Calculate Combo Bet Winnings in Football when Betting on Draw (X)
Unlike calculating combo bets for Asian Handicap and Over/Under, the formula for calculating combo bets on the draw (X) is simpler. When the capital is determined, you only need to plug in the corresponding amount of money into the following formula:
Combo Odds=Odds of the 1st bet x Odds of the 2nd bet x Odds of the 3rd bet x ... X Odds of the nth bet.
Sharing experiences to maximize combo bet winnings
After understanding what combo bets are and how to calculate the winnings for combo bets, the following experiences will be the next key to success for bettors to remember.
Prioritize single-match combos to increase the winning rate
As mentioned earlier, combo bets consist of a series of odds played together. Therefore, to secure a victory, it is necessary to predict the majority of the outcomes in the series.
Hence, choosing single-match combos is a sensible option for those who lack experience. Prioritize allocating capital to teams with higher odds and names that you can confidently rely on to minimize risks.
Time your combos correctly to support capital multiplication
Timing your combos is crucial and is a valuable tip from experienced bettors. You can apply the method of running a diagonal combo, which means betting against what you previously placed during the betting experience. If you know how to run combos correctly at the right time, you can effectively control the win-loss ratio.
See more betting tips at : soccer tips sites
Wintips has provided information on what combo bets are and shared some betting experiences. We hope that these recent insights have answered readers' questions and will support their upcoming capital multiplication journey.
